You put the resistor in the circuit that FEEDS the coil...cutting the 12V input down to the 6V that the coil can handle. You are NOT using the resistor to cut the voltage below 6V.
If you keep your electrical system 6V, there is NO NEED for a resistor in the ignition circuit. AND if you switch to a 12V coil, there is no need to have a resistor in the circuit.
YOU ONLY USE THE RESISTOR WHEN USING A 6V COIL WITH A 12V ELECTRICAL SYSTEM...AND THEN ONLY TO REDUCE THE INPUT VOLTAGE TO THE 6V COIL DOWN TO THE 6V INPUT IT WAS DESIGNED TO HANDLE. YOU DO NOT USE THE RESISTOR ON THE OUTPUT [DISTRIBUTOR/POINTS] SIDE OF THE COIL.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
