I push a lot of snow with a 200. Only time it is any problem is when we get snow and it blows so it gets hard. I have one set of weights and a rear blade. On the front I have a loader with a blade. I took the regular blade off and mounted a combine tire I cut in half. It works great. You don"t need to worry about hitting something and breaking anything. It also high and concave so it works like a scoop and holds a lot of snow. Before I had the loader I had an old straight arm loader frame mounted to the rear axle and used 2 cables and pulleys run off the touch control.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
