Posted by D Slater on January 23, 2011 at 14:36:26 from (184.15.40.132):
In Reply to: H head cast# posted by lo HP IH owner on January 23, 2011 at 11:46:20:
That is a distillate head. If it just has a D following the number, you have a early H if the head is original to it. If it is a early H the frame rails you wanted to change in the other post may use the rubber mounts between the engine and the frame rails. IH went to solid mounts between the frame rails and engine because of frame rails warping in around early 1942. If you have the rubber mounts I would support part of the weight when changing the rails. I think its a good practice on the solid type. Even if its not a have to thing.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
