The carb was a boat anchor with the amount of rust. I have never used acid on a carb on any of the hundreds I have rebuilt until this one! Thats how bad it was! I did not soak it I carefully bathed and rinsed, scraped, sprayed and cleaned on it for hours-after, I had removed every thing that was removeable. Deperate means call for desperate measures! RUSTY is there a metering jet that you cannot see or access with a wire or jewelers bit? If so it could very well be plugged where I am not getting fuel through the power circuit. As far as the governor goes I think it is O.K It seems to be functioning properly.( limits top rpm, pulls back etc.) Thanks
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
