Posted by Brownie 450 on February 12, 2011 at 18:00:29 from (66.43.241.198):
In Reply to: 560D starting problem posted by 400Dtractorman on February 12, 2011 at 17:05:08:
You'll have to trace the hot wire back to the pushbutton switch paying special attention to the connectors on the wire ends. After this, check for voltage from the pushbutton back to the key switch or ammeter--again paying attention to connectors. If no success here, check for voltage from the solenoid terminal on the starter which feeds the key switch or ammeter. Can't remember if there is a fuse in the pushbutton starting circuit or not--I don't believe there is one.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
