Posted by bob-b on February 13, 2011 at 00:25:53 from (75.171.165.228):
HAS ANY ONE SWITCHED OVER TO ELETRONIC IGNITION, AND HAD ANY PROBLEMS WITH IT. I AM THINKING OF CHANGING MY IH 230 OVER.[STILL 6V] HOW HAS IT WORKED FOR YOU. DID YOU KEEP IT 6V OR CHANGED TO 12V. EITHER WAY HOW IS IT WORKING. DOES IT TAKE LESS CRANKING TO FIRE OR ABOUT THE SAME. DOES IT HELP THE MOTOR RUN BETTER. THANKS
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
