Posted by mkirsch on February 14, 2011 at 05:48:53 from (64.80.108.57):
In Reply to: Looking at 756 posted by W6tractor on February 14, 2011 at 05:01:00:
There are no problem areas on these tractors. If there were, they would not still be running after 43 years. Everything is going to be worn, obviously.
The grinding may or may not be an expensive problem. Depends on if there is any adjustment left, and if adjustment fixes the problem or not...
Diesel or gas?
"Jerks before stopping..." WHAT jerks? How are you stopping? Coasting to a stop, or applying the brakes? Clutch pedal in or out? Neutral or in gear?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
