Nolan! This is nothing new the 460 560 and some 706 with 282 would do just as you have said. Problem is 2 fold sleves did not fit tight enough abd the sleve did not have right undercut just under lip so they would crak and in time you find them in the pan. There was some different OD's to mahe them fit better. All I ever did was to paint the out side with aluminum paint. You can see if you can still get the bigger OD sleves. Most likey the block is oh.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
