It just slides out, but if stuck like most there's no way to drive it out. Sometimes soaking and light pecking for a few days helps. hard to do but if you can get it to turning, it can be worked out. Heat and cool also if needed. Hard to weld anything to the end also but a small nut can be and used to turn and work out with a grip tool. Lot easier to do with top cover off.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
