Posted by Andrew Z on February 27, 2011 at 03:58:12 from (64.252.115.246):
In Reply to: 300 TA ??????? posted by Farmall Dann on February 26, 2011 at 18:20:29:
It sounds like the TA is cooked, make sure you have the TA Clutch adjusted correct. Also dont use the TA as a engine break, they will free wheel leading to more damage. Make sure it is adjusted first and go from there.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
