Re: Farmall H with single front wheel
Posted by CNKS on March 14, 2011 at 19:16:31 from (216.144.104.128):
In Reply to: Re: Farmall H with single front wheel posted by LaBoyteaux on March 14, 2011 at 18:58:32:
The M "high crops" were cotton picker tractors, although the HV and MV could be modified to accept a single front. Although cotton was planted in wide rows, the dual wheel NF would probably cause some damage to a mature plant. My dad also had a wide front on an H. I was too young to know why he did that. Much harder to turn around. Our culitvators matched the 80 inch rear tread on the H. Wide fronts took over in the 70's and 80's, more likely because of perceived safety concerns -- cultivators became wider also, so turning was less of a problem.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
