Re: Farmall H with single front wheel
Posted by John A. on March 14, 2011 at 21:56:59 from (76.1.122.180):
In Reply to: Farmall H with single front wheel posted by John in Mich on March 14, 2011 at 18:24:58:
John. Here in Texas a lot of us call them "Cotton Fronts" As others have said they were useed a lot in the cotton farming operation.
Bedding or cultivating the single front is a lot easier to operate and easier to turn when one turns around on Headlands over a dual tire narrow front!
The High Drum tractors had cotton pickers mounted on them and these tractors had a high version of a single tire set up. And these tractors ran in a reverse fashion for it had a change up in the trans so it would.
Ease of steering is the biggest benefit to a single front tire! Hope this helps!
Later,
John A.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
