Posted by Janicholson on March 20, 2011 at 11:29:47 from (64.61.211.243):
In Reply to: 350U hydraulic problem posted by tom dowling on March 20, 2011 at 09:06:05:
The control handles can fail. It will feel like a dead chicken leg if it is stripped at the control. If it feels Normal, does the engine bog a little when attempting to raise or lower, If so the safety valve in the cylinder might have gotten stuck. If it does not it is in the inside hydraulics. The pump drives the distributor, so the shaft is OK. The key on the shaft turning the gears in the pump could be sheared, (not high likelyhood). The suction screen could be blocked, or the tiny regulator valve and screen could be stuck. Keep us informed. Put blocking under the blade or take it off before relieving pressure! Jim
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
