Posted by pintobill on March 21, 2011 at 15:48:54 from (174.253.136.19):
I have a H that is set up for pulling. It has a M carb. On it. The tractor has been running fine. The other day I put a different governor on it. After I got it all back together it started up and idled fine when I went to give it some throttle it basically died. now when I try to start it the motor will crank away but as soon as you try to choke it the motor acts like it is vapor locking. Any help would be appreciated.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
