Posted by pintobill on March 21, 2011 at 16:02:30 from (174.253.136.19):
In Reply to: H will not start posted by pintobill on March 21, 2011 at 15:48:54:
Here are the things that I have checked. It is firing It is getting gas Changed plugs I can't see anything binding up in the governor The carb and the governor tube are attached correctly I took the carb apart and seen nothing wrong with it I pulled the distributor out and checked to make sure nothing was broke And I re-timed it
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
