Posted by El Toro on March 22, 2011 at 04:05:57 from (108.3.200.96):
In Reply to: Re: H will not start posted by pintobill on March 21, 2011 at 16:02:30:
If reinstalling the old governor doesn't help you should pull No1 sparkplug near the radiator and bring No1 piston to TDC on the compression stroke. Then look at your rotor to see where its pointing. It should be at the No1 plug tower. Make sure your plug wires are in the correct firing order on your cap. Hal
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
