Posted by Jim Becker on April 21, 2011 at 11:37:59 from (173.57.144.251):
In Reply to: mounted plow posted by rustred on April 20, 2011 at 18:15:59:
If you have to brace it you are wasting a lot of energy and pulling power on side draft. That is typical of many of the shop-built aftermarket hitches. The guys building them don't have the slightest idea of how a 3-point is supposed to work and they mess up the draft. They are probably OK for a post hole digger or a platform carrier, and maybe good enough to get along with a rear blade. But they are usually no good for any real tillage work.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
