Posted by TSEliot on April 25, 2011 at 09:52:08 from (129.72.158.11):
My H runs wonderful, but when I shut it off after about ten uses, the starter will not turn over, even with a charged battery and a clean ground. Swapped in another starter off my M, and everything was fine again until about the tenth time. Swapped in a third starter, and same thing. Starts up fine until about the tenth time, then nothing. Hooked each of the three starters to jumpers and they all worked fine.
I am hoping this is just a bad switch, and not something mechanical. Any ideas?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
