Posted by pete 23 on April 27, 2011 at 18:43:53 from (74.44.100.190):
In Reply to: Farmall 560 PTO posted by Robbie Gooch on April 27, 2011 at 13:51:10:
Well, all of the internal parts, over center mechanism etc are subject to wear but the biggest problem I have had to repair on the clutch type pto is that it wears the keyway out in the operating shaft. I used to replace the shaft of course as they were reasonably priced years ago, but now days, I cut the key way out and install a larger key. Last one I did I used a dremel. Not quick and easy but my labor is cheap nowdays. Thing is, you have to look real close to see that the lever is moving and shaft is not following it to same degree therefore not much movement where you need it to get over center engagement and still able to apply brake.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
