Posted by Marlin taylor on April 28, 2011 at 11:58:39 from (34.254.119.222):
filled the lift all sytem with oil. Per advice i recieved here, pulled back on the lever and could feel resistance. As well the engine loaded up. A week later, the lever still has resistance, but there is no load on the engine as before. Anyone know why, is that good or bad etc...? Also, the dip stick was loose--not attached to the cap. Should it be?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
