The cap or cup over end of valve is pushed down with the decompression mechanism and is under neath the rocker arm shaft. If you wanted to take the cup off you would have to remove whole rocker arm assembly. They are a regular shaped valve but very small, and open into the spark plug, gasoline side combustion chamber therefore lowering the compression ratio for starting on gas. Usually you can get them to move down a little but getting them to move back up is a little harder. You might be lucky and be able to do so from spark plug hole but those two center ones are really hard to get at. May have to take manifold off. They have to move totally free and also not leak when seated. They are very prone to warping when not cooled on their seats. That is why I suggest checking by cranking with spark plugs removed with lever in diesel position as first of all if stuck open you will have total compression leaking out through the plug hole and if they are closed but leaking you will have some leaking. A slight leak can be tollerated .There are other ways to also check them but this is simplest.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
