Posted by AG in IN on May 14, 2011 at 17:15:40 from (67.236.82.255):
In Reply to: 1949 M Revs Up posted by gold1456 on May 14, 2011 at 13:07:37:
What rustyfarmall said plus there is a small grooved pin that holds the lever in the front to the shaft that goes between the gov. and carb. that can break too. The pin may not even look broken, but see if you can twist the lever arm on the end of that shaft.
I fixed a 400 last year and that was the problem, it would run idle or wide open. Pin looked just fine until I took the gov. tube out and could twist the lever on the shaft.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
