Posted by Larry Ed on May 21, 2011 at 11:57:36 from (67.142.175.27):
I have a 1944 Farmall A and it has been converted to 12 volt. It starts every time except today. I turned it off and when I re-started it, I got a spark off the negative post on the battery and nothing happened. I got my volt meter and I have 12.65 volts at the starter switch. But still nothing. I took the switch off of the starter and touched to positive cable end to the post on the started and nothing. What should I do next? Thanks everyone. Larry
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
