There are two different clamps. 5368D is the inner clamp and 5369D is the outer clamp. The inner clamp has two "feet" on it. The outer only has one. Assuming the hub of the cast center is toward the outer end of the axle, the inner clamp with two feet when tightened keeps the wheel in alignment with the cast center. The outer clamps, when tightened evenly all the way around, center the rim on the cast center. Tighten the outer clamps in a criss-cross pattern and you will end up with even spacing between the rim and the cast center.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
