Posted by B tank on June 16, 2011 at 16:37:22 from (68.149.56.30):
In Reply to: acetylene B tank posted by mike paulson on June 16, 2011 at 15:51:20:
They're very small and mostly used for plumbing and portable torch sets. If you just want a normal torch set that you don't have to carry into akward places, go with larger cylinders than a B tank. They will be much more economical and last a lot longer too. You go through the small O2 cylinders like crazy.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
