Posted by Janicholson on June 23, 2011 at 20:54:31 from (67.72.98.47):
In Reply to: Help again posted by Richard W on June 23, 2011 at 17:38:02:
Were it mine I would realign the arms where bolted together and weld them tight to avoid shearing the bolts while carrying a tool. Weld all around on both sides. I would replace the links and pins with adjustable screw links (one with a crank to operate it). It looks just about strong enough to handle the H if not abused. The weights are interesting. Tough to remove W/O massive effort. It will do the job, Jim
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
