Posted by AES on July 05, 2011 at 19:10:28 from (12.40.5.69):
I sent my gas tank to the radiator shop to be lined and asked them to remove the studs. In attempt a stud was stripped off (even after heating it cherry red) so need to find a "new" stud for the shop to use. They can tap the hole and weld in a new stud if needed.
Does anyone know what size those studs are? The shop person said they must be metric as they are not 7/16 and not 1/2". Did IH use metric in the 50s?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
