I checked the parts book. The coil has the typical wire going to the distributor, The only "ballast resistor" is within the voltage regulator. There are two of them. One goes to the ground. The other goes to "relay" So I am assuming I should try a new regulator. Or could the ballast be internal to the coil? Thanks for any sugeestion. Electrical is beyond me..
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
