Posted by SadFarmall on July 23, 2011 at 03:36:45 from (121.219.129.4):
I have a 1939 Farmall M and the battery box has been moved down beside the brake drum on the near side. This was a change made in the early 1950s by Cherry & Sons, who manufactured a bracket to suit. It is a convenient place and it makes getting at the battery very easy. On my Farmall H, there is, as yet, no battery. I believe it is meant to fit under the fuel tank, but the belt pulley gearbox looks like it will be in the way. Am I missing something or is there another place IHC recommended the battery be placed? As the H is much smaller than the M, I am not sure if putting beside the near side brake drum is a good solution.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
