Posted by rhtx55 on July 27, 2011 at 16:28:13 from (207.119.63.253):
In Reply to: H head rebuild posted by Jim Paterson on July 27, 2011 at 14:26:29:
More modern engines ( which I am sure he is most used to) have replaceable stellite seats on the exhaust valves, if the seats are shot in your present head, they can be milled out for these replacement inserts.
The guides are certainly replaceable but the factory head came with the "seats" as part of the head casting, normally, they just need to be 'ground" with a standard seat grinding machine to match the profile on the valves.
You may want to call around locally & find someone more familiar with how to fix the valves on your tractor.
This post was edited by rhtx55 at 16:29:21 07/27/11 2 times.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
