Hi RTR, I guess you figured out to block the wheels so the 684 does not run over you. Check for oil leaks from under the dash and from under the cover on the top of the transmission. This is where the brake lines run. The other possibility is the brake wheel cylinders are leaking. Hopefully the parking brake still works. Be very careful always to disengage the parking brake before moving the tractor.
Nice looking tractor and loader. Did it have a T/A and someone removed it or the plug for the hole to the left of steering column was just lost?
My brother has 454,495,684 and 3230 with 2350 loader.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
