Posted by mkirsch on August 23, 2011 at 08:20:43 from (64.80.110.74):
In Reply to: Log splitter posted by devo on August 22, 2011 at 11:30:08:
Switching the cylinder out is easy, it's two pins and two hoses, but make sure you don't already have a 4" cylinder. The tube should measure between 4-1/2" and 5" in diameter.
A 4" diameter, 24" stroke cylinder is pretty common on tractor-powered log splitters. I bet you already have one.
More than 4", cylinders get very expensive, very quickly.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
