I'm with d282, it could be a bent- broken rocker arm or a bent push rod. My dad owns a 966 with D414 and we have had 2 rocker arms fail and one push rod to get bent and it did the same thing with a little knock each time it did it. The engine in this tractor must be a early model- the new rocker arms are heavier built than the ones on it that fail. FE
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
