Also, are those stock rear tires and rims on your M? They look a little fat, that's Ok as it will help your traction but will make the furrow wheel alignment a little more critical. When centering measure to the center of the tires and adjust from there. I like the front wheel to be adjusted about 2 inches from the furrow wall to the inside edge of the tire. This will provide the best guide when steering straight and remember you still want to avoid knocking the furrow wall down.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
