Posted by glennster on September 22, 2011 at 08:21:07 from (76.224.4.21):
In Reply to: Stuck Clutch? posted by Grumpydaniel on September 22, 2011 at 08:07:26:
i have an h that the clutch will stick if it sets a couple weeks. i block the pedal down when i park it so it doesnt happen. when it did stick, i would drag the tractor out of the barn, point the front end toward the field, plan an escape route and start the tractor in 4th gear. keep applying both brakes with the clutch depressed while the tractor is running to break the clutch loose. if you can hook it up to a plow or disk, you can pull the implement with the clutch down till it pops loose.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
