Posted by Grumpydaniel on September 22, 2011 at 10:56:38 from (24.210.178.147):
In Reply to: Re: Stuck Clutch? posted by Mike1972chev on September 22, 2011 at 09:11:09:
Well, this ain't going good. Short of trying to overturn the tractor beside a tree, I've tried hooking to a heavy object (1959 MF-50) and popping it loose (failed), and tried setting up a vibration by rapping on the clutch with a BFH and a large drift pin (failed, too). IU even tried chaining the Massey to it, putting the H in 4th and popping this way (with the clutch pedal blocked open, of course), and it just drug it across my concrete shop floor. (I did, however, get a better idea how tuff that little Massey is!). But this ain't working. Do I need to drop the hydraulic pump and disassemble the thing?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
