Posted by glennster on September 22, 2011 at 11:06:48 from (76.224.4.21):
In Reply to: Re: Stuck Clutch? posted by Grumpydaniel on September 22, 2011 at 10:56:38:
i just noticed in your original post you have a lot of play in the clutch pedal after you worked on the shifter. you may want to drop the belly pump and take a look in there to see what is going on. you can loosen the clutch and see if you can free up the disc, then spray some brake cleaner in there to clean it up some.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
