You can only remove the seal, not the bolted plate. Removing the plate will destroy the pinion carrier, it will not come out. Just pry out the seal. New seals will likely be thinner. Put them in so they do not rub in the groove of the old seal. Pack the back side with chassis grease to assure it is lubed. Some times people put in two seals per side. That also works if grease is put between them. Jim
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
