Posted by Loren in Iowa on October 07, 2011 at 17:28:55 from (207.177.2.187):
Got the M split, and the bearing on the hydraulic pump drive shaft seems real loose. Pulled the seal housing, and need some advice on how to remove the bearing from out of the front of the transmission. Does it pull right out, or is there a trick? Would like to replace it.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
