Posted by Wardner on November 16, 2011 at 14:36:53 from (4.154.235.176):
I was going to take oil from the IPTO seasonal disconnect plate and return it to the spare shifter plate on the rear frame lid.
This should be much better. The 560 hydraulic pump is constantly circulating Hy-Tran into the filter cavity. My add-on front-mounted hydraulic pump will draw oil from the cavity and suck it through a large strainer partially seen on the right.
I sprung for a high capacity IH oil filter extension and filter. Figured it would reduce the negative head for oil going to the IH pump. I also added a drain plug to capture the oil when changing the filter. Don't know why IH didn't do that.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
