Not really ready to post these pictures but since you asked, I just shot these.
The pump will power a winch, outriggers, and a small crane.
The lever valve will run the winch/hoist. The two spools connected by cable will set the outriggers and elevate the boom. The crane won't be ready for several weeks. The valve bank is not attached to the tractor frame. It is secured to the snowplow frame. The crane and snowplow can both be mounted at the same time but probably won't be.
When the crane is off, I can use the outriggers to lift tractor so that the winch can pull better. I am also thinking of putting wings on the snowplow. They would use the cable spools from the "cab" to power rotate them for max width or angled ahead for scooping.
The snowplow is power down or floating. Does a fine job pushing compost or scrapeing loam/brambles. Been thinking of chaining up all four wheels. Only need to buy the front chains. I think I have a set for the rears.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
