I fixed the wobble in my H by grinding off 1/4" of the back of the worm gear, and installing a 1/4" spacer between the worm gear bearing and the gear. This pushed the worm gear 1/4" back, so thicker teeth are in contact with the circle gear. Took all the slop out of the system. It seems to work perfectly. I've driven on several highways in road gear, and actually forgot about worries about steering. Works in the field too.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
