I asked the question many years ago in an electrical engineering course in college. A couple explanations:
1 - Positive grounding was simply the early engineers' arbitrary choice.
2 - Oxygen molecules (the key element involved metallic corrosion) tend to be more attracted to the negative side of any circuit. By making systems positive ground (ie wiring is negatively charged relative to ground), wiring and connections tend to be less affected by corrosion.
My experience after 40+ years of fooling with both + and - grounded systems has me leaning toward #1. I suspect the designers had to agree on a "standard" ground polarity. Someone tossed a coin and positive ground was the winner. (Then I'll bet they all adjourned to drink beer by a fire on a cold winter day - just like I'm doing now...)
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
