The fuel is another issue and I haven't experimented since I don't have my distillate setup complete as of yet. Here in the states kerosene is quite a bit more expensive than gas or diesel and that would be a sticking point for widespread appeal.
I don't think it would be necessary to destroy your original to make a new mold. Some careful measuring and inspection should be more than enough to generate the needed dimensions. I think the trickier part would be getting the right kind of cast iron to take the heating and temperature differential without cracking. As to the heat valve perhaps using stainless parts would be the most cost effective on a low volume run.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
