Posted by rustcollector on January 16, 2012 at 07:18:38 from (67.142.161.21):
In Reply to: A transmission seal posted by cheif on January 16, 2012 at 06:36:34:
Chief,
If you know the clutch is in good condition, it is best to use hoist and/or splitting stands or good blocks, jacks and split at the transmission letting the drive shaft pull out of the clutch. Once you get about 4 to six inches of separation you might be able to unbolt the drive shaft and leave it sticking in the throwout bearing tube. If so, tie up the back end of the shaft and don't put any pressure on the throwout bearing tube as you could break it. Do not release the clutch as the alignment with the pilot bearing will be messed up. Then remove the nut on the transmission yoke. Good idea to inspect the coupling and replace worn parts. Trick is getting the shaft held up to go back into the throwout bearing tube in reassembly if you go too far and the front end slips out of the throwout bearing tube. A three ft piece of garden hose (or similar) slid through the throwout bearing tube and down through the clutch inspection/adjustment hole, then slid over the pilot bearing stub on the shaft can serve as a guide.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
