Posted by J.D.HEICHEL on February 16, 2012 at 12:27:34 from (67.235.2.111):
Can you use the crank and rods from a Super MTA diesel in a 400 diesel block ? The smta block is cracked and we can get a good 400 block with the same part number. I was told 400 rods have a longer stroke than the smta. Can we use the smta head on the 400 block ? The smta head was repaired and is good to use. I also need the long throttle rod for the SMTA diesel if anyone has one laying around. The ones from a MD are shorter. You can e-mail me.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
