You hear air escaping while cranking? Sounds like foreign material under the valve. If you pulled it out of the weeds, animals may have been storing food in the exhaust and it fell in there when the engine was first turned over. If the air intake system was open, there's probably a mouse nest in the manifold, and got sucked down in there. Or simply a valve was in the open position all this time, and the face is rusty. Any one of these problems would clear up with 30-45min. of idling time. If not, pull the valve cover and check valve clearance.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
