Posted by gbs on February 24, 2012 at 16:58:49 from (71.54.133.55):
In Reply to: ethanol question posted by charlie M on February 24, 2012 at 13:52:09:
question is what are they using instead of ethanol for additives,have any of you all noticed the rust eating away at the metal filler necks and tank caps sense low sulfur diesel started being used,also seen an article about northern areas having to add sulfur to the land, wasn't a problem according to the article until after sulfur emissions were reduced
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
