Cheaper than gas, in WWII it was probably more available than gas. Kerosene is similar. Both are lower on the refining scale than gas and produce less HP. There is currently 0 advantage to them, only kerosene is currently available. HOWEVER, IH said that an engine ran best on the fuel for which it was designed. Supposedly that means that a kerosene engine will produce more HP on kero than gas -- not sure I believe that.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
