Distillate fuel requires less refining then gasoline or even kerosene for that matter. Since it is cheaper to refine it was less to buy. This was the advantage to this the down side was lower power out put due to the low compression of a distillate burning engine. Example of this would be the Farmall M you mention they have around 34/35hp ias a distillate and 39/40 hp as a high compression gas. If the compression of a distillate is too high generally over 4 to 4.5 to 1 it will have a tendency to knock. Another factor to consider when burning distillate is that it does not fully burn in the chamber and can dilute the crank case oil. You would back off the top petcock on the oil pan everyday and drain off the un-burned fuel. There is a ton more info out there on this just google it and im sure you can find out more facts.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
